Linked Revit file hatch pattern isn't showing?
    Hi all!
    My problem is that one of the linked files contains the life-safety info as color fill areas and linework. I have all of the VG settings turned on to allow for each of these to come through, but the hatch patterns are missings (ie all I have is the area outline). How would I go about importing the custom hatch patterns from the arch model LS plans so that they can be shown in necessary floor plans? Any help would be greatly appreciated!
    Thanks in advance!
    -Kcaparella
    Don't really know on linked files, but you'd probably need to be in a Area Plan View in your host model to see the patterns... Might this be the problem?
    Other wise, try transferring the Color Fill Legends and apply one to your Area Plan.
      What version of Revit are you working in?
      -Alex Cunningham
        mdradvies,
        This worked. Thanks!
