Automatic Sizing
    Automatic Sizing
    How do I define sizing for automatic pipe sizing?
    I get that I click a pipe on the system then click the duct/pipe sizing calculator but how can I define the pipe sizing as per our company standards? We have a manual method at the moment where we look up on a table and see that a flow rate (velocity only) of between x & y would require a copper pipe diameter of 1/2" and a flow rate of between y & z would require a copper pipe diameter of 5/8" etc.
    Where can I set that?
    By the way, I did quite a lot of fiddling to get 'flow' through the piping systems I made. It was all to do with the connectors; their flow rates, preset or calculated and the Hydronic Return or Supply thing...but it works now!
    Ciao for now.
    Say something interesting....
    I believe it is controlled by the Mechanical Settings under Pipe Settings > Sizes.. Those checkboxes under the column "Used in Sizing". Once cleared they won't be used for the Automatic sizing in MEP... Please correct me if I'm wrong..
    “You can't think AutoCAD and run Revit.”
    -Anonymous
