Filter/Sort per level.
    How to filter/sort vertical long-run pipes and ducts per level?
    going out on a limb here: probably only possible when you draw them as separate pieces per level...
      filter as in multiple selected and filter down to categories, or filter as in VG?
      Your best option is to create a shared parameter and assign it to pipe and duct, than give it whatever type of parameter to your vertical pieces.
      Than you can sort them in a schedule or filter in VG based off of the parameter.
