Best practice work flow out there for creating builders work opes in Revit MEP?
    Hi there,
    What is the best practice work flow out there for creating builders work opes in Revit MEP 2012?
    I would like to be able to place builders work opes in walls and floor/roof slabs and then be able to scheduled out the builders work opes.
    Currently I've created a 'cube shaped' family mass in Revit MEP which can be placed in the MEP model and then inturn can be picked up in both the linked in Revit Architecture and Revit Structure models where the actual opes will be cut (modelled) into their relevant models elements.
    Thanking you in advance.
    Rob
    Pretty nice workflow if you ask me...
      One issue I have with using the massing workflow is that is doesn't schedule off room spaces.
      I did some research and I found a useful builders work workflow that was presented at the buildingSMART BIM International Conference 2011 and I've also included some revit tools that will assist the cutting of the BW opes. Refer to links below.
      http://www.buildingsmartsingapore.or...nstruction.pdf
      Cut Opening Tools:
      Tools4Revit | Cut Opening
      Tools4Revit | Smart Floors
      Rob
