Wiring in MEP 2010
    Wiring in MEP 2010
    Hi again,
    how to wire the Panel and the lighting Fixture as in my case
    1. Panel is on the wall is- Lighting and Appliance Panelboard-480V MLO Surface.
    2. lighting fixture i have created in the ceiling is M_Ceiling Light- Linear Box 0300x1200(1 Lamp)-120V
    While wiring, Diagonal Box pops out with warning saying can not wire " Cannot add 0300x1200mm(1 Lamp) - 120V to Circuit. The Number of Poles for 0300x1200mm(1 Lamp) - 120V does not match the Number of Poles (3) for the Circuit."
    Help me out...... pls Frens n Sirs here in Forum.....
    as the warning says, you have to match the no of poles for the elements in the circuit and the panel itself. you would have to link the parameters in the Edit Family interface for both to be able to adjust the no of poles in the Project interface or simply adjust the parameters in the Family..
    “You can't think AutoCAD and run Revit.”
    -Anonymous
      The panel you've used is 480VAC while the fixture you are using is 120VAC. There is a mismatch in distribution systems. You have to use as panel that is assigned to matching voltage. Typically the 480 panel would connect to a transformer that would "step-down" the voltage to 120. The secondary side of the transformer connects to the 120VAC panel and the light fixture is connected to that panel. It really just mimics the way they work in the field...
      • Electric panel selection in drop-down box.
        When I set up an electrical circuit and select a panel name in the drop-down box the same panel name is repeated over and over. Seems every time I add...
        March 19, 2014, 01:46 AM
      • Revit Circuiting Question
        Hello,
        I have a question for Revit MEP users:
        Is it possible to circuit/wire fixtures without cluttering the drawings with lines,...
        February 5, 2016, 02:06 PM
      • Cannot assign Space or Spare to empty circuit?
        I have an 18 slot electrical panel schedule with one receptacle, one light fixture, and two 120v/1ph motors. These are taking up only four breakers, leaving...
        November 15, 2013, 02:53 PM
      • Adding lights to panels
        I am trying to add a 120V light to a 3phase panel and just use one of the phases to power the light. When I click on the panel to add the light to the...
        May 15, 2013, 01:57 AM
      • Electrical circuiting
        Our engineering firm is just starting to use the circuiting and panel schedules provided in Revit. We are doing a lot of hotels now. Some with 120 guest...
        September 25, 2014, 08:31 PM
