Hatch Patterns for Diffuser
    Attached a air terminal that I would like to use in my project. What I want to achieve is it should show honey comb hatch pattern on it's face. Was able to Put the hath pattern within the terminal but when we use it on the project it's not showing. Attached the revit family.
    Any leads would be greatly appreciated.
    You need to edit that hatch in your project, not in the family. If a hatch is already in the project it will use that, no matter what you do to it in the family.
      Noticed it's in the model too but still didn't get it work, snapshot of Fill patterns in the model.
      Shan1512
        Opened your family and noticed that the materials of 2 of the 3 objects were not linked to a parameter (just the circular extrusion was). So change that too, so the material from your project actually works on the family.
          Hi Robin, did this and it override the visibility of the spigot in the floor plan. However updated the drafted the drafting pattern on to the face plate and it did worked.
          Sincere Thank you for your time and love this forum .
