Reducer Tag - doesn't orientate direction correctly
    When I place a tag on my reducer fitting it always places larger to smaller size, when the pipe goes the other way it doesn't flip always stays larger size first then smaller. Looks wrong on the drawing when placed.
    Any solutions would be appreciated.
    Is it an OOTB tag, can you post it?
      It's a generic tag that was edited for this purpose but just not quite working as needed.
        That is just the way that tag works. If you look at either the size or overall size parameter of the fitting this is what it's pulling. It always reads larger to smaller. If you could add the independant radii family parameters (like nominal diameter 1) then you could do this, actually you couldn't because every different family has there own named parameters. You're just going to have to run with the way it is.
