Pipe Fitting Symbol Problem
    I am having problems with my pipe fittings, and the same for pipe accessories. Looks at the attachemnts. The elbow of the green pipe is in question.
    Basicilly the elbow show graphically different at different elevations. Below the cut plane pipe looks good, above, not so good.
    Thanks in advance.
  • Pipe Fitting Keeps dissapearing
    I have a pipe fitting that when I draw a pipe to/from it everything is fine. When I connect that pipe into the main branch the fitting disappears. Can...
    June 17, 2015, 11:12 AM
  • Automatic Pipe Fitting - Reduce pipes
    Hello.
    I'm making my own pipes fitting, but i'm having problem with my reducer.
    When I deduce the pipe ø104 to ø79, for example,...
    October 14, 2016, 07:10 PM
  • Pipe Fitting Junction Family
    Hi there,
    I am looking for a pipe fitting family that will enable me to create this PVC pipe junction: Refer to Screen Shot....
    January 24, 2012, 01:57 PM
  • Wye combo w/ 8th bend
    I have inserted the wye combo w/ 8th bend into my project and have used it some. Now I have one look up off a sloped pipe and would like to add a vertical...
    December 16, 2014, 07:49 PM
  • Pipe fitting issue
    Hi There,
    I created three different elbows of 30, 45 and 90 degrees and corresponding branches . My requirement is , pipe should be able...
    January 29, 2014, 04:24 AM
