compressed air setting 6bar
    doeas anyone have the parameters for custom compressed air setting that must be filled in (schedule of mechanical setting ) dynamic viscocity and density of compressed air (6bar)?
  • Setting Fresh Air Temperature
    Dear All,
    i have a mechanical system which described bellow:
    Fresh air comes from HRV (Heat Recovery Unit) unit.
    Heating Cooling is...
    February 18, 2015, 06:21 AM
  • Shared parameters between categories
    Hi All,
    I have a questions regarding the „reading“ of parameters between categories.
    For instance, inside my Air Terminal...
    April 4, 2017, 10:30 AM
  • Duct system - outside air / supply air
    I am trying to calculated my system pressure loss for my whole duct system. My system consists of :-
    Supply air terminal
    Air handling...
    August 19, 2014, 07:24 PM
  • Duct Systems
    I'm curious as to the proper way to do this.
    System description:
    Outside air through ERVs to bring it up to a minimum temperature...
    January 9, 2017, 06:39 PM
  • Outside Air System
    There is a bit of controversy here as to what an Outside Air system is to be based on. This is the air that goes from a louver via plenum/duct to the...
    August 26, 2014, 06:16 PM
