System Type Colours
  • kubsix
    The same does work with Sanitary systems. There must be something not quite right between the settings. Hard to diagnose without the file.
    Recommend assigning color in the Pipe System properties only. Assign the solid pattern without color with the filter.
  • fifthtexas
    started a topic System Type Colours
    System Type Colours
    I am in process of doing above ground drainage, I have created my sanitary pipework in standard colour green.
    I am now putting in my rainwater and have created a piping system duplicating sanitary, renaming it RWP I have then done my type properties and changed the graphics override to a different colour blue.
    I have also created filters with the same colour I require. I have then created my pipework and in properties and states system type is RWP
    but my RWP pipework will not change colour to blue it is staying green same as my sanitary pipework.
    I have gone wrong somewhere any ideas?
    I have created all my other pipework MCW, DHW etc and assigned different colours with solid fill and the all work ok.
    why cant I do with sanitary?
  • Filters
    I am new user to revit MEPI am trying to create a project using different pipework, I want to have these coloured red for hot, blue for coldI have managed...
    May 2, 2014, 01:23 PM
  • Change Linked File Colour
    Hi guys,
    Please see image.
    How do i change the colour of the pipework from a sprinkler model that i have linked into my MEP...
    September 18, 2015, 02:34 PM
  • Outside Air System from Supply
    So I find the creating a new duct system to be a bit of a joke, especially when any supply based system HAS to be duplicated from Supply Air. I have created...
    July 3, 2013, 03:47 PM
  • Displaying/Filtering pipework on sheets
    How do you guys separate different pipework on different plans?
    I wanted to use filters and filter them by System Type but it System type...
    January 23, 2015, 01:35 PM
  • How to change system type of pipework
    i have some pipework from a model that has a system type of other, how can i change this to another service say hydonic supply
    it wont let me change...
    November 13, 2014, 04:46 PM
