Change the color for the conduits rise and drop.
    Does anyone know how to change the colors for the conduits rise and drops in the floor plans? I have been overriding by element and it is only works as the one single color. Maybe it is something to do with the view range or something else.
    Object Styles > Model Objects > Conduits. Expand this Category and change the Rise and Drop subcategory. This will make the change project wide. If you do not want to make this change project wide, then make the change in Visibility/Graphics instead.
    The reason Override by Element doesn't work is because that only overrides the Parent Category and not the Sub-Categories.
    -TZ
    Tannar Z. Frampton ™
    Frampton & Associates, Inc.
      Thank you so much for reply; I’m not sure what’s going on, but I tried already and it is didn’t work, revit put rise or drop on the same color.
