Hide crosshairs on vertical ducts
    Hello!
    How do i hide crosshairs on vertical ducts without hiding centerlines?
    Nope... no way to hide only the cross or change the size.
    Its one of those 'CAD' standards that have been built into revit.
    They can be useful for aligning/dimensioning to vertical ducts and pipes though.
    But if it REALLY bothers you enough, you can either turn off center lines..or..
    You can mark all vertical pipes/ducts with a parameter (https://www.revitforum.org/mep-gener...pe-filter.html)
    Then hide them all with a filter, so you only see the vertical fittings which have no cross, and the horizontal pipes/ducts.
