Air Terminal Question
    We ran into a small issue that I'm having a hard time understanding concerning air terminals and was hoping to get some clarity.
    When in a RCP view, viewing a terminal that has rectangular or round duct connected directly to it without using flex duct, the connected duct becomes visible and pick-able through the terminal itself. I don't know much about families but it would appear that the extrusions are solids and there is no indication that they should be transparent.
    I've attached a picture of two terminals side by side. The one on the left has a rectangular duct connected directly to it. The one on the right is just the terminal. For what it's worth, I am aware that they are flippable and that they come in "upside down" when placing in RCP. They are both oriented correctly.
    I'm trying to understand why the duct work is showing up through what is suppose to be a solid. Any help would be appreciated!
    Welcome to the forum....
    You are seeing the ductwork's rise symbol, which is handled as annotation. All annotation is moved to the foreground.
    You can remove it by turning off the Rise sub-category or the Duct parent category.
    John Karben | IMEG Corp.
    • Duct and Terminal Connection
      Hi, i am using Revit MEP2012 Trail Version.
      and trying to study HVAC System Design.
      While trying to connect the main supply duct to terminal...
      July 31, 2012, 09:58 AM
    • Is it possible to array air terminals on a duct?
      while making them all attached to the duct ofcourse.
      and anyway.. how do i attach an air terminal to a duct? revit says the air terminal...
      August 10, 2016, 09:33 AM
    • Air Terminal on Duct and Groups
      I would like someone to try this in Revit 2014:
      Create a duct run and place four air terminals on the duct (using the "air terminal...
      June 4, 2014, 07:15 PM
    • air terminal on duct
      hello
      i've got an issue
      the wierdest thing is that it was working last week but i need to modify it and now it doesn't work anymore
      December 10, 2019, 08:44 AM
    • duct 2 flex
      hello
      is there any way to convert duct to flex?
      there's a command which permiet ton convert a duct to flex from an air terminal bu i xould...
      June 18, 2018, 12:13 PM
