Question- please respond quickly!! thanks
    is it possible to make a clearance around a model in Revit? baiscly a see through box around a model?
    Yes-
    You could place a Mass, with a transparent material, around an entire model. Just out of curiosity, why would you need to do this?
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      ohh ok.. how exactly would i do that? im creating a BIM model for a rooftop unit. and we need to show the clearance so that when people open the cabinets or the drawers, there will be plenty of room for clearance. but unfortunatly i only have till 430 today to try to fingure this out and how to do it.
        I usually do this with symbolic lines and have a visibility parameter tied to them so I can turn them off and on....
          That sounds like another idea... How exactly would i do that so that when the 3D view is on, the lines of the box for clearance is shown?
            OK--thanks for explaining the purpose--that helps.
            You could add some thin transparent wall based families into the RTU/Mech unit family ( or nest them in), give them a visibility parameter so that when loaded into your project you can turn them on/off as desired.
            You could also still nest a Mass with a transparent material into the Mech Unit Family and control it's dimensions with height, width and
            length parameters. Mass is turned off by default in Visibility/Graphics, so remember to turn it on in views where you need to see the "imaginary box" around the unit. Better yet create a View Template which has Mass on and apply it to those views.
            cliff collins
            BIM there, done that
            Cliff B. Collins
              ok perfect!.... is there a way you could explain that to me kind of step by step like (go to the annotate tap, click masking region) cause unfortunatly i am still a "teenager" so to speak to the Revit world. Sorry for makeing this complicated.
                Can't right now--stepping into a meeting.
                But--you should be able to very quickly open the Mech Unit Family, then create some "walls" around it at correct distances/heights, assign them a Material Parameter,
                Assign them Visibility Parameters ( on/off ), then Save the Family, Load into Project, and assign the "walls" a transparent material and/or visibility settings for the views where you need them to show up.
                Cliff B. Collins
                  oh ok. no problem. I'll see what i can do.. Thanks for your help. i really appreciate it.
                    We actually model clearance masses for collision detection. Works great!
