Objects dissapearing from template/view
    Hello,
    Hope it's clear on images. I opened project today to find out that pumps objects disappeared from some of my views. As you can see on img 2, I can't unhide them, even if I switch template to NONE. For some reason applying 'working' template from bottom views, doesn't change pumps visibility, but applying some of templates created by someone else, in past in this project, does. I played with this template - all filters, worksets, model visibility, but still no solution. I obviously can work around that, but maybe someone has experienced that kind of issue?
    Thanks a lot
