Electrical template - unable to see the metallic structure
    Hello,
    I linked my structural project in an electrical template..I copiy/monitor the levels and I created new structural plan views for the new levels!
    But when I go to the floor plan I cannot see the metallic structure of the building that I have. do you know why?
    Thank you in advance!
    Maria
    If you are using the electrical template, the views are already pre-filtered (generally) by discipline.
    Set the discipline of the view to coordination and it should show up.
    if this doesnt work, it may be that the view has the linked model turned off in the view, or that the linked model has been assigned to a workset, or phase and is being filtered using one of these other criteria, but the view discipline is where I would start.
      I cannot change the discipline in the Copy/monitor level...
        no, im talking about the view properties. The actual properties of the view. Not the objects or anything else but the VIEW which has most likely been set to electrical discipline.
          yeah , when I am in the view (that I created from Copy/monitor and after I create a new View Plan) the discipline is 'electrical' but I cannot change it because it is grey.
          • Co-ordination plan views
            HI
            I am new to revit mep, its heavy going, so much to take in.
            can anyone help
            I have created my first project have tried to set it...
            May 1, 2014, 01:57 PM
          • View Templates
            I have created a new project using the electrical default template and then a new view power plan. when I apply the electrical view template all my devices...
            January 17, 2014, 03:58 PM
          • Default view discipline
            RME2011 only has 2 options -> Electrical or Mechanical, which will even override "Apply automatically to new views of same type" when using...
            July 22, 2011, 12:45 AM
          • Creating views
            I thought I was doing this correctly, but maybe not. Let me walk you through what I did.
            I have a view. Floor plan. I copied it, left...
            January 13, 2011, 09:52 PM
          • Linked models are not showing up
            I have two problems.
            1. I have the arch model linked into my electrical model but for some reason the fire wall lines are not showing up. I don't...
            June 24, 2015, 01:43 PM
