Pipe Tee's or Tap's
    Pipe Tee's or Tap's
    Every once in a while if I have a run of pipe that is not connected to the main line it does weird connection things. Instead of a Tee coming off at a 45 it will bump the pipe and come off vertically as a Tap. Other times will connect to the main but then add two or three other random fittings. Just wondering if others have had this issue and how they fixed it? Or if someone knows if I have something set wrong? I am using R16.
    The short, not-exactly-helpful answer is that this screwy behavior happens sometimes with pipes and ducts. It's gotten better than it used to be back in the 2010-2011 days, for what that's worth. The thing I've noticed about this screwy behavior is that it's consistent, there's always some specific thing you're doing that sets it off. Figure out what that thing is... and then don't do it. Like I said, not exactly helpful!
    All that said, I never use Taps for pipes.
      Ok That is what I was thinking it might be. For now it doesn't really matter if I use a Tee or a Tap but at in the future we are wanting to do more prefab and then I will need to use Taps at the right time. Thank you for your input.
      • Creating Pipework Routes
        I am still trying to get used to working with Revit, finding it frustrating, seem to be going 2 steps forward 3 steps back.
        I appreciate all the...
        February 1, 2015, 11:04 AM
      • Connections Pipework
        new to revit MEP on first project trying to connect pipework to boiler, I have added a potterton boiler, has connections
        I am trying to connect...
        May 22, 2014, 11:21 AM
      • Error - No auto-route solution was found
        I keep getting the "No auto-route solution was found" error.
        Drawing the pipe perpendicular is ok, drawing...
        May 13, 2020, 01:16 PM
      • Pipe disappearing issue
        Dear all,
        I am confused,....
        Any one can help me and give me a several reasons for disappearing the pipes from the floor plan.
        I am...
        September 13, 2016, 09:41 PM
      • Reducing Tee glitch?
        I created a Reducing Tee but when i try to stretch a sloping 6" pipe that is at a higher elevation to a perpendicular sloping 12" pipe, it says...
        October 22, 2015, 03:07 PM
