Cable Tray Noise Barriers
    I'm new to Revit and can't find any information on handling noise barriers in cable trays. Seems like an important item to have in a cable tray design. It would also be needed for an accurate Materials List.
    Could you elaborate a little on this item? Essentially, what is a cable tray noise barrier...?
    Thomas N Fuller II
    LinkedIn
      A barrier strip in installed in raceways and cable trays to separate high voltage cables from low voltage and signal wires so the noise doesn't interfere with the signals.
        I understand clearly now. But unfortunately I don't have the answer you want.
        Thomas N Fuller II
        LinkedIn
          If it is IN the cable tray it wont be possible to model it easily (And why would you want to?) but you could easily add a parameter to your cable trays for Noise Barrier (Yes no tick box) or Number of Noise Barriers (Integer). Then in a schedule do Tray Length x Barriers to get the quantities.
          • Cable Tray Reducer
            how to make left side and right side cable tray reducer in revit-2017
            :bb:
            please help me. I'm new revit user
            June 10, 2016, 12:02 PM
          • Cable Tray Clearance Space
            What's the best way to place clearance for cable tray? I wish cable tray had an option similar to piping insulation except it added clearance space....
            May 21, 2015, 03:22 PM
          • Cable tray type
            Hi everybody
            If i want to create cable tray type (for example cable tray LV and cable tray ELV). How do you load difference cable tray types...
            November 24, 2015, 04:01 AM
          • Drawing Cable Tray on an arc
            Got do draw a run of cable tray 1 metre offset from an arced wall. I've drawn a detail line as a marker. Please see image attached.
            What's...
            May 18, 2016, 03:15 PM
          • Cable tray wall offset
            Hi all,
            please help with the cable tray fixing in-wall... check the image ... the tray not coming properly.
            You do not have permission to view this gallery.
            This gallery has 2 photos.
            September 20, 2021, 05:34 AM
