Publich Health Design on Revit using BS standards
    Dear Revit users,
    I have a question about using BS standards on Revit public health designing.
    Is there are many differences between BS and IPC standards.
    As you know Revit uses IPC codes as a default and i am also got used to IPC standards. However the Company which interested in to hire me, going to ask me BS standards and i am worried a lot about it. Any suggestion will be highly appreciated. What are the difference on BS fixture units and IPC fixture units? And also what is differences on conversion of fixture units to flow rate between BS and IPC?
    Thanks
    Vusal.
    Take a look at this for calculating to other standards using schedules.
    or if you can do a bit of programming check out this; The Building Coder: User MEP Calculation Sample
    Im not much good at C# but I managed to modify this example add in to do flows from fixture units based on a dutch standard.
    • Fixture Units Below 1?
      When I set my fixture units to 1 the corresponding l/s is 0.189. However When I go to 0.5/0.250.001 fixture units this value remains the same? Obviously...
      March 14, 2016, 12:33 PM
    • Hydraulics, Flow, configuration problem
      Hello everyone,
      When I access the family editor from Revit 2017 and check the configurations of an original MEP Toilet, the "flow configuration"...
      November 7, 2016, 06:15 PM
    • Cap Family to Generate Fixture Units
      I'm trying to create a cap family that can generate fixture units for flow tracking in our projects. My intended workflow is:
      Draw pipe to connection...
      May 16, 2018, 10:40 PM
    • Fixture units
      I’m a newbie when it comes to Revit but want to get as much out of it as possible. I am keen to note up the fixture units on my drawings. I have watched...
      April 17, 2014, 02:52 PM
    • Fixture units not reading on all items
      I have got my fixture units set for my waste/sanitary connector on my sinks, why I inspect the system the units are reading on some sink but not others...
      May 19, 2015, 09:57 AM
