Cobie data
    Cobie data
    When filling in the cobie data for Air terminals etc.. do you input the location per terminal or is there anyway of cobie picking the data up directly from the spaces
    Make sure your grilles room calculation point is turned on in the family & is below the grille & it should populate that for you
      so when i export the cobie data on and open it in excel and the room locations should be populated?
        Yes but you have to have Spaces with the room names within your model too
          do you have any examples of what it should look like with cobie data filled in? in the past the architect has taken care of all this.
            Not at hand but will post some ASAP
              cheers for that.
              I thought I had would have to manually input all the location of equipment item by item
                did you manage to find any cobie mep stuff
                  On my template, I have Space Categories (Uniclass 2015) and Ocupancy Zones parameters associated with my rooms. Whenever I am filling data from the room, I am also populating this data to help the MEP guys later.
                    Have you got an example please
                    for uniclass2015 do you just add a parameter to your familes and fill in the add the relevant uniclass category to the family?
