“Double branch ducts” before what should be a shoe takeoff from a sub-main duct.
    Revit 2017.
    Above is a screenshot of my problem.
    (Iknow that there is another line of ducts there in fade but I will join them later to the automatically generated system when that is done, if I have that idea correctly.)
    1 — I have selected all the supply terminals and the indoor unit as shown.
    2 — I have next selected to “Generate Placeholder” in the “Modify|Multi-select” contextual tab.
    3 — I have lastly selected to “Edit Layout” in the “Generate Layout” contextual tab.
    At this point, I can see that some, if not all, the otherwise sub-main ducts from the main duct have doubled up from the same main duct joint forming two branch ducts on the same route instead of having one sub-main duct to a shoe take off.
    I have looked in the help file and I have also looked on some Revit forums but cannot find anything
    Can anyone advise?
    Many thanks. Tim. :thumbsup:
    Tim Stretton ¦ AutoCAD MEP 2D & 3D & Autodesk Revit.
    (Used AutoCAD since release 12 & 13 in 1996. Learning Autodesk Revit, not BIM yet)
    “Eppur si Muove! (It [the Earth] still moves!)” —— Galileo Galilei (15-05-1564 › 08-01-1642)
  • Issues with duct lining
    I received my model from an engineer or architect (not sure which) that contained a layout of the duct system in a building.
    The specs require...
    February 14, 2012, 02:46 AM
  • Stuck with this
    I have a case where a piece of rigid duct is replaced by number of (could be 4,5 or more) flex ducts. I have to use a round duct tap....
    April 27, 2018, 04:49 PM
  • Takeoff position
    How do I control duct takeoff position?
    Sometimes it takes off from side of the duct, while other times it takes off from top or bottom -...
    January 11, 2019, 09:26 PM
  • Duct bends not being drawn in when I try to automatically connect the ducting
    I am using Revit 2017.
    I am trying to connect a duct from a shoe to another existing duct which has a different offset but...
    March 8, 2017, 02:09 PM
  • Duct connections
    I have a 700 x 700 duct and have another duct 700 x 300 above, which i want to drop down which i would like to connect it into
    i cant seem to do...
    December 4, 2014, 10:44 AM
