duct system check
    duct system check
    when I run Check Duct system, this message appears:
    Mechanical Supply Air 12: It is not possible to calculate the flow since the flow direction mismatch. Please check flow direction on all equipment in this system.
    Ducts : Rectangular Duct : Radius Elbows / Tees - Mark 1034
    Duct Systems : Duct System : Mechanical Supply Air 12
    Start by checking how you have your connectors setup on all your equipment (bidirectional flow will cause this)
      I could solve the problem, but another problem surfaced
      Mechanical Equipment : AHU-Rooftop-Carrier 48TC 15-28 ton : TC017 - Mark 7 : id 812430
        Looks like you're using a manufacturer family. This is almost always bad news if you're trying to do anything other than have it look pretty. If you're trying to actually get it to work with your systems and schedules, you'll spend so much time wrestling with it that you'd be better off just making your own family from scratch. I avoid manufacturer families unless absolutely necessary, i.e. I'm in a rush and don't have time to make it from scratch.
