Insulation
    Insulation
    If you use the insulation tool in Revit MEP 2012, then the insulation is over the whole length of the selected pipe. Is there an way that the insulation is over a portion of the pipe and not the whole length?
    Nope. Not unless you split it.
      Oke, too bad. Thank you!
      • Can not delete insulation off pipework
        Hi
        i have taken over a job which has all the pipework with insulation on, I need to work and make changes, I have removed the insulation, but it...
        March 12, 2019, 04:39 PM
      • Pipe Insulation for Tees - Garbage!
        Alright, the title of this thread is just my frustration over Revit's insulation for tees.
        They look like big triangles. Has anyone overcome...
        June 13, 2015, 05:59 PM
      • Pipe spud insulation issue
        Hello all,
        I have a pipe spud that I use (attached) that works great with its flexibility for everything I need it for except when it comes...
        November 13, 2011, 08:11 PM
      • Pipe Insulation
        Hello
        As you can see i'm trying to insulate the piping system and everything is fine, but when i want to insulate the header (collector), the end...
        July 26, 2018, 08:26 AM
      • Dimenioning off of insulation
        I am trying to space out my hydronic and domestic pipes with insulation. We like to install them with 2 inches of space between the edges of the insulation....
        August 14, 2017, 03:43 PM
