Revit - Dialux link
    Revit - Dialux link
    Good evening chaps.
    Does anyone have any details of the fabled Revit - Dialux link? I have heard rumours of such a device however have raked about to no avail.
    Neither Revit nor Dialux seem to boast of this which I take to be a bit of an ominous portent.
    Can anyone comment on their own knowledge of this?
    Ta
    Krebsy
    Don't cry, don't raise your eye, it's only Revit wasteland.
    Hello Mog505,
    The program MagiCad (a library program for Revit) has a function to link Revit to Dialux.
    Erik E
      Revit > Dialux
      Originally posted by Eriknash View Post
      Hello Mog505,
      Erik E
      Could you tell me a bit about that? im a student a currently working how to get Revit > Dialux and if possible back( as it its possible with the Dialux plugin for autocad MEP)
      Best regards
      Niels
        Revit to Dialux means the use of gbxml export, for a room by room study. No knowledge about the Dialux plugin for MEP, sorry.
        Julien
        P. DAC
          Yes i know that way, but the plugin i mentioned enables you to also export the data out of dialux, and have all the luminaries imported to your model
            hoe to get megiCAd plugin
            Hello Mog505,
            Erik E
            hello,
            how we can get megiCAD plugin. i m able to export Revit to DIALux.i have two main quires
            1.DIALux output is in STF format.so how we can import that output into REVIT?? without using plugins. via any other 3D format
            2.Anyother way how to import Dialux outpot into REVIT.
            Pl help me out
              You can export a 3D dwg from DIALux its not a revit family but it dose put a 3d object of the correct size & elevation into revit & in the right place
                Thanks for reply
                how and in which format we can export dialux file.
                in dialus i found only STF format (3D )
                pl update me
                  hi,
                  thanks for reply,
                  pl tell me how to export from dialus.. In dialux only STF format is ther for out but in Revit there is no option for import STF file.
                  pl show me way how to do
                    in DIALux just go to file, export, save dwg
