Circular Duct Taper Issues
    For some reason when using round ducts the taper is not loading and I get an error message when trying to change sizes. Looking at the round duct routing options there in no taper/transition loaded and it does not appear to exist in the duct library. Any help would be appreciated as I cannot progress a project until I get this resolved.
    First, go to this folder on your local drive (or, the directory in which your content was installed to) and find all the fittings you will need for your project, and drag/drop them into the project itself:
    Code:
    C:\ProgramData\Autodesk\RVT 2016\Libraries\US Imperial\Duct\Fittings
    Then, go to your Duct Types > Routing Preferences to set the default fitting for each function.
    -TZ
    Tannar Z. Frampton ™
    Frampton & Associates, Inc.
