Duct Takeoffs
    Duct Takeoffs
    I've set two types of junctions for a duct type in the routing preferences, however, I cannot switch between the two. They are the OOTB fittings one beveled, the other standard. It seems that the top one is the default but I cannot switch to the other one which I've included in the routing preferences.
    Do I need to setup another duct type in order to utilize two types of takeoffs for the same system or is it something in the families that needs to be changed?
    Unlike other fittings, these cannot be changed via properties, but the priority can be set on the fly via routing preferences allowing more than one type on a system. So far, the fittings type stay as set when adding additional branches. Still need to do more types of edits to see if/when the assigned type changes.
    Loading...
