Unfortunately, after years of experience with Revit MEP, the best advice I can give is.... Dont use Groups.
I keep trying to use them, to see if autodesk have made any improvements, but then also get problems like this.
I just had a project where part of the installations was the same on 10 floors, so I tentatively made a group and copied it. Changes to the group worked fine. Then the next day I tried to open the project and was given to options: Cancel (Dont open the model. Obviously not an option) or Ungroup. So then I had to spend ages clearing up all the ungrouped **** on 10 floors...
Alongside that kind of problem, pipes get randomly disconnected, groups sometimes create new Types of themselves because something undetectable has changed in one of the instances, the Group Editor is terrible with very limited functionality, you cant update or overwrite a family if it is in a group.. I could go on...
Revit actually has 4 ways of creating repeated groups of components; Groups, Assemblies, Families and Linked Models. All of which have their own limitations.
Groups are highly unreliable, Assemblies are useless for MEP as they cant contain pipes and ducts, Nested Familes work great but cant contain Systems.... So I am increasingly pushed to use small linked models as Groups because they are stable and do everything required as far as propagating changes to all copies is concerned.
I think Autodesk are slowly moving towards using links as groups too because they have improved the 'Save Group/Sheet to New File' and 'Bind as Group' functions a lot. If you get used to pushing parts of your model out into a separate model (Save Group or 3D view on a sheet as new file), linking multiple instances and pulling them back in when required (using Bind Link) this can be very powerful. Although many links does lead to longer model opening times.
"One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Groups are definitive not the best way. There are many problems with it. I normalu use them in the first phase. We want to place out all the components so that we have a correct bill of material. The next fase I ungroup all.
I want a solution that have the best from groups, assemblies and shared/nested families. MagiCAD are working on manipulating assemblies so that we can use it. But my opinion is that this is something Autodesk needs to fix. Either changes how groups/assemblies work, or design another "family".
I have a number of typical room layouts for an assisted living facility that are groups and I keep running into issues when I need to modify them. The...
I'm using groups on a condo project with some success. Generally speaking, if something goes wrong and I need to fix the group it's not a problem. I just...
1. Is it me, or has 'swing-in-from-the-browser' whilst in group edit mode broken?
2. Is it my content, or have...
August 30, 2017, 08:11 AM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
