Really custom electrical panel
    Our firm is led by an electrical engineer who wrote an AutoCAD electrical add-in to do full load calcs, panel schedules, etc. We are moving to revit and are starting to look at the OOTB panel schedules compared to the ones in autocad: They are very different!
    We have been unable to make a schedule that looks like this.
    The easy thing to say is "just use the OOTB ones" but we obviously want them to look the same as our previous ones.
    Can anyone offer a suggestion on how to proceed?
    Thanks.
    You will have to give into Revit in order to use its Panel Schedules. The circuit schedule is very doable to get close to your AutoCAD original with very little adjustments. The calculation part of it, you can show some info but nothing like what you've got lined up currently. This will have to be done separately. But you can place these two items together where it looks like one seamless schedule with some work on formatting. Start simple, and work up to complex Panel Schedule Templates in time.
    -TZ
    Tannar Z. Frampton ™
    Frampton & Associates, Inc.
    • Double tub electrical panel?
      Hi everyone. From a quick search around it doesn't seem possible, but I was wondering if anyone here has found a proper workaround for creating a double...
      March 14, 2017, 11:19 PM
    • Revit Circuiting Question
      Hello,
      I have a question for Revit MEP users:
      Is it possible to circuit/wire fixtures without cluttering the drawings with lines,...
      February 5, 2016, 02:06 PM
    • Electrical circuiting
      Our engineering firm is just starting to use the circuiting and panel schedules provided in Revit. We are doing a lot of hotels now. Some with 120 guest...
      September 25, 2014, 08:31 PM
    • Revit MEP - Panel Schedule question
      I'm helping out the electrical department to set up their Revit standards. They wanted a panel schedule that showed the breaker size and number of poles...
      February 16, 2016, 12:50 PM
    • Electrical Panel Schedules
      I am self taught in Revit. I am using Revit 2016 to create electrical panel schedules. I have already edited panel schedule template...
      August 12, 2016, 09:59 PM
