hello all! my name is jared and I have been useing Revit MEP for a long time now. But recently I ran into a dilema. Please help if you have found a salution.. So i wanted to easily just copy and paste from one dwg to the other like Inventor, but that option isnt available when you right click the part that you want to copy. Is there another salution to this? Cause i really dont want to have to redraw the part.
Revit MEP-help!
First off you need to have BOTH files open.
Select the families you want to copy. hit ctrl+c or cut to clipboard in the modify tab (this is not a right click option).
In the second file either hit ctrl+v or the modify tab there is a paste button with multiple options.
Now keep in mind it isn't as always as easy as copy/paste. RMEP families share relationships with connected families. So getting a portion may not work. Sometimes it is easier to create a group and than copy/paste the group than ungroup."Keeping my view range hopeful"
I've been using an empty custom node as a clipboard to copy/paste between different graphs (clipboard.dyf). Does anyone know of a better way to do t...
Channel: Dynamo BIM
March 31, 2017, 06:39 PM -
Ok I have just installed revit on my computer about 20 minutes ago.
my first 20 miinutes with revit in my life.... :-)
what i want to ask...-
January 7, 2013, 12:11 PM -
I am trying to copy a walls from one revit to another revit project.
When I "copy to clipboard", then after pasting into another project...August 29, 2017, 05:11 PM -
Hello,
Anyone know if you can copy/paste a bunch of walls from one level to another. I tried to highlight all my walls then hit the copy...November 3, 2013, 10:07 PM -
For such a powerful piece of software. so many features just seem to be very poorly implemented!
Copy/Paste is one.
I have...December 6, 2012, 09:14 AM
Monumetric Footer In-screen
