Hi All,
as I was googling I found out that the usual way to define fresh air in AHU is like supply air, right? Now I am interested how to define parameters for flow on AHU connectors? I assume that they should be shared parameters, but do I need to assign separate shared parameter for each type of flow or one shared parameter is enough for all type? For Example, should I have:
Shared parameter = Air flow (used for all connectors on AHU), or should I have
Shared parameters = Supply Air Flow; Return Air Flow, Exhaust Air Flow, etc.
Best regards, Branimir.
