Riser Duct Visibility Issue
    In my project I am facing an issue with visibility of fresh air riser duct. This riser duct running from GF to Third FF.This duct is visible at all floor levels except first floor level. If I disconnected a riser from a elbow which is @ 2300 below first floor level then duct is visible if i connect it to elbow then it is not visible. I had checked all possibilities related visibility but I am not able to fix it.
    Any suggestion?? Any clue??? to fix it.
    Yogesh
    Sounds like you have a visibility setting defined by systems. When the duct is connected it becomes part of a system. Check in VG and look at your filters.
      System Type
      At Last I found an issue.The issue is, I need a fresh air system for ducting and by default it is not available with RMEP so I added it as a other system.As their is no any default presentation for other system so that the riser duct is not visible in plan if it is connected fitting. As it disconnected from a fitting it becomes visible.
      I heard that in 2012 we will be able to add a new system type...hope so it will be work fine for 2012.
      Yogesh
      • Duct set down/setup - visibility Issue
        From One challenge to another and thanks for this forum offering solution.
        Currently the floor plan has filled duct system color through...
        December 10, 2020, 10:17 AM
      • Issues with duct lining
        I received my model from an engineer or architect (not sure which) that contained a layout of the duct system in a building.
        The specs require...
        February 14, 2012, 02:46 AM
      • Stuck with this
        I have a case where a piece of rigid duct is replaced by number of (could be 4,5 or more) flex ducts. I have to use a round duct tap....
        April 27, 2018, 04:49 PM
      • Invisible duct risers
        Hi everyone,
        I'm having an issue in Revit 2012 where all ducts drawn that run perpendicular to the plane I am viewing are invisible, i.e. duct...
        August 18, 2011, 06:37 PM
      • Flex duct keeps connecting to top of duct
        Hey guys, I cant figure out why my flex duct keeps making the connection to the top of the duct. See attached screen shot. Thanks!...
        April 6, 2012, 07:56 PM
