Count Plumbing Fixtures for each pipe
    Hi guys =)
    I have a question and I do need a help....
    Let me explain my problem with an example please:
    let's say that I have:
    2 Wc's
    1 Wash Hand basin
    1 bath
    All of them are connected to cold water.
    Do you think it's possible to add a parameter to the pipes and see for each pipe how many WC, Wash Hand Basin, Bath, etc... are connected to it?
    For example, if I click to the pipe number 1 the parameter will say:
    connected WC= 1
    connected Wash Hand Basin= 0
    Connected Bath= 0
    If I click to the pipe number 2 the parameter will say:
    connected WC= 1
    connected Wash Hand Basin= 1
    Connected Bath= 0
    If I click to the pipe number 3 the parameter will say:
    connected WC= 2
    Connected Bath= 0
    If I click to the pipe number 4 the parameter will say:
    connected WC= 2
    Connected Bath= 1
    Thanks guysssss!!!! =)
    Yes its possible... but takes a bit of work.
    I did something similar for tap water calculations to a european standard. It required 2 different kinds of fixture unit (for auto flush type valves and for normal taps) as well as constant flow rates to be taken into account. However pipes can only be set up to add a single parameter through the network, either a Flow (eg use a Hydronic Return system) or Fixture Units.
    So how do you get multiple parameters to be counted in the single parameter that is available in the system?
    My solution was to use multiples of 1, 100 and 10000 in the same number parameter.
    So in your WC family you set a FU of 1, in your washbasin you set a FU of 100, in your bath you set a FU of 10000. Then if you have 2 WCs 3 washbasins and a bath on one system the total FU will be; 10302
    In a schedule you can split this back into individual numbers by dividing by 100 or 10000 and rounding up.
    If you have more than 99 of something then you might have to use larger multiples of ten..
    • extra parameter for pipe
      Hello,
      I would like to add extra parameter to the pipe that would work just like the "Flow" parameter.
      I created radiator...
      October 10, 2017, 11:44 AM
    • Can I Use Calculated Project Parameters?
      Hello,
      I am trying to build some simple features into a rainwater drainage system. I have built the rainwater outlets, and in the family...
      April 7, 2014, 03:47 PM
    • How To? Fixture Units to SF within Pipe.....
      OK, So I probably confused you all. Here is what we are "trying" to do. In our Roof Plumbing plans, we show Roof/Overflow Drains with the coverage...
      July 10, 2013, 12:49 AM
    • Piping units.
      Good morning,
      I'm very new to Revit MEP and have a problem
      In the commercial refrigeration division I work in, equipment is described...
      April 7, 2011, 06:01 AM
    • pipe sizing in revit
      does anyone know and have basic steps for calculating pipe sizes within Revit. All i have been able to find are duct sizing methods but nothing for pipe...
      May 6, 2014, 12:28 PM
