Elements not visible on one PC - but visible when same file is opened on another PC!?
    Hi All!
    I'm having some issues with a MEP Revit file I am currently working on.
    I worked on it without issue for the the last 3 days, However, this morning when I opened up the file all the components (mechanical) are missing (I don't think anyone else worked on it over night).
    The Revit links (architecture, structural etc) are all still visible, just the mechanical elements are missing.
    I tried all the usual things which usually result in elements going missing (work-sets, phasing, isolating hidden, templates, visibility/graphics etc), but the elements appear to be gone missing.
    I appended the same Revit file into Navis & all the elements are showing up as per normal!
    Also, A workmate opened up the same file on his PC & its working fine for him - we all work off MEP Revit 2015.
    Has this happened to anyone before??
    Any help will be much appreciated!
    Thanks.
    are any of the worksets closed?
