Actual Lighting Load per Area
    Hi guys! I'm newbie looking for help. I've attached 2 files. Run Elect. This is a simple assignment.
    "Change the light fixtures in the Sage Rm. to a 2 tube, 40 watts per tube fixture.
    Change the photometric web file to 2x42T12.ies."
    What is the revised Actual Lighting Load per Area for the Sage Rm?
    I changed photometric web file to 2x42T12.ies, but i cannot see any changes with Lighting Load.
    I'm not able to attache one more file here I don't know why.
    Any advises what I'm doing wrong here?
    I'm not able to attache second file.
    noki
    I'm not sure if the file you attached is the one you are using but it has rooms placed. If you are trying to find this value then you will need to place spaces not rooms. Spaces have mep information associated with it that pick when families are added in them.
      Problem is solved. Thank you all.
