Reducing Tee glitch?
    I created a Reducing Tee but when i try to stretch a sloping 6" pipe that is at a higher elevation to a perpendicular sloping 12" pipe, it says no auto-route solution was found.
    After switching the routing preferences of the reducer to off, the same scenario works perfectly. it appears that Revit tries to put a reducer after the reducing tee, which makes sense why its failing, but is there a way to avoid that without having to disable the transition in the routing preference?
    It's not as tedious as having to manually place the fitting, aligning it, drawing a pipe upwards and connecting the incoming one, but if i could get it to work perfectly without having to change the routing preference would be a nice.
  • Wye combo w/ 8th bend
    I have inserted the wye combo w/ 8th bend into my project and have used it some. Now I have one look up off a sloped pipe and would like to add a vertical...
    December 16, 2014, 08:49 PM
  • Wye Connection off sloped main pipe
    I'm on the architectural side of things playing with RME so i'm not really too familiar with this (although have read the shortcomings of sloping pipe):...
    March 12, 2011, 08:18 PM
  • Pipe fitting issue
    Hi There,
    I created three different elbows of 30, 45 and 90 degrees and corresponding branches . My requirement is , pipe should be able...
    January 29, 2014, 05:24 AM
  • Pipe Fitting Keeps dissapearing
    I have a pipe fitting that when I draw a pipe to/from it everything is fine. When I connect that pipe into the main branch the fitting disappears. Can...
    June 17, 2015, 12:12 PM
  • Pipe Fitting Connections to each other/NO Pipe
    Is there any way to connect two pipe fittings without using pipe?
    Please see attachment. (Ah, I see the moderators have changed the attachment...
    August 16, 2011, 07:34 PM
