Pipe Insulation for Tees - Garbage!
    Alright, the title of this thread is just my frustration over Revit's insulation for tees.
    They look like big triangles. Has anyone overcome this? I tried adding through the SysQue add on and still the same.
    On a practical level, it does interfere with clash detection. However, to be honest, this is more of an emotional reaction to something ugly I have to explain at the BIM coordination meetings.
Name:	Pipe Tee Insulation.JPG
    First, insulation is created via Revit, not SysQue. I wished Kenny and the gang had control over it, but they don't. If they did have control, it'd probably be way better.
    Wanna see dumb insulation? Loot at high-efficiency duct taps.
    I'd love to see the ADSK team clean up the insulation creator.
    Thomas N Fuller II
    LinkedIn
      Damn, was hoping someone here had a solution or some insight into how piping insulation is applied in Revit. I'm trying to figure out exactly how Revit applies it, but am so far fruitless. Obviously, I also am frustrated with the ugly and inaccurate geometry of insulation on fittings and accessories.
      It seems to just apply it to the nominal diameter from connector to connector, so a straight accessory or fitting with only two connectors works okay. Once there is a third connector it starts to look bad.
      What I am trying to do at the moment is apply 50mm of insulation to a lugged butterfly valve, but like I said Revit starts the insulation at the nominal diameter. So the result for my valve is insulation that looks like only a few millimeters. So what I really want to know is how to control (if possible) the start point of the insulation.
        sorry kool... cool!!! just now came to know about this post.
        Length of T-matters e.g. I took 300 dia pipe tap of T-length 1st pic shows 225mm and 2nd pic shows 275mm for the insulation thickness of 75mm.
        T-length need to be modified based on insulation thickness and diameter of pipes.
Name:	Pipe Insulation1.png
        -RG-
          Tee lengths will not be modified by our family supplier as they are based on manufacturer spec sheets.
          Thomas N Fuller II
          LinkedIn
          • Can not delete insulation off pipework
            Hi
            i have taken over a job which has all the pipework with insulation on, I need to work and make changes, I have removed the insulation, but it...
            March 12, 2019, 03:39 PM
          • Valve insulation
            How Revit insulates Pipe accessorise because in one case Revit insulates everything fine and in other case insulation is broken?!
            Please...
            October 27, 2015, 07:43 PM
          • Pipe Insulation
            Hello
            As you can see i'm trying to insulate the piping system and everything is fine, but when i want to insulate the header (collector), the end...
            July 26, 2018, 07:26 AM
          • Insulation
            If you use the insulation tool in Revit MEP 2012, then the insulation is over the whole length of the selected pipe. Is there an way that the insulation...
            August 23, 2011, 12:52 PM
          • Pipe insulation issues
            Maybe this subject has already been through here, but does anyone know if there is a way to split the Revit pipe (and duct) insulation in another way...
            June 6, 2017, 06:47 AM
