Copy Monitor Pipes
    Copy Monitor Pipes
    I can copy monitor walls doors and stuff like that but how come I can't link in my Mechanical Consultant's model and copy monitor his pipes?
    Copy monitoring is designed for elements where the ownership can be shared between different disciplines - ie walls can be Architectural or Structural, Sanitary Fittings can be Architectural or Plumbing.
    There is no reason for an architect or structural engineer to have ownership over pipes so no reason to copy monitor them.
    Dan Morrison
    BIMTelligence
      I'm a mechanical contractor. I primarily do pipes and ducts. But when I link in the mechanical engineer's model I can't copy monitor the pipes and ducts. Besides, there is no Revit MEP anymore. It's just Revit. How would it know whether I am a MEP, structural, or architectural trade?
        Revit was developed originally as a design tool to be used in the design process, hence why the copy/ monitor tool is meant to be used between architects and structural/ MEP Engineers, or occasionally between different services engineers.
        Personally, whether in design or construction, I wouldn't use copy/ monitor for anything other than Grids and Levels, it is a tool that is fraught with too many problems when actually used on real projects of any size.
        Dan Morrison
        BIMTelligence
          Thanks for that tip. I wouldn't use it to copy monitor the whole thing just useful elements like plumbing fixtures and grilles. Naturally extended to some connecting systems. Kinda sucks if I can't get the exact position. Maybe I can add my own families and use align.
            What's wrong with Copy/Paste?
            Tannar Z. Frampton ™
            Frampton & Associates, Inc.
              I do that too...just that I am also trying to develop a better workflow with my modeling team and I remember copy/monitor was a quick way to copy something in on the fly without stopping to open another model and hunt it down.
              I use the SysQue Add on and the way I have it in my mind was to copy/monitor the exact position of WCs/FDs etc, then switch them out with the fabrication models I have from SysQue. Cheers!
                The problem with copy/paste (that I have found) is that the systems classifications are lost. Then you have to try to figure out what systems they are suppose to be, and this is very time consuming and a big pain. I wish you could use copy/monitor for this application. I am also using Sysque and would definitely make our work flow much safer and faster.
                  Yeah it sucks that the systems get lost. I just tried another method to see if it would work; Save a view of just what you want to copy as a separate file, Link it, Bind the link. But unfortunately that also kills the systems. They look just fine when linked but then go to undefined when you bind.
                  Maybe you could do each system one at a time in this way, then you know what the system type should be for all the undefined stuff.
                  Although, there is no easy way to set the system type even if you do know what it should be, as Undefined is the only option in the list...
                  Maybe another one for the Dynamo ToDo list...
                    I've accepted the idea that I will still have to re-model most of the consultant's work.
                    In doing so, I have to start with my project template which has my custom predefined system types.
                    Therefore, the way I have this in my mind is to copy/monitor in a bunch of stuff, and even if it's undefined, it would take on the system type of the pipes I would eventually connect to it.
