Displaying/Filtering pipework on sheets
    How do you guys separate different pipework on different plans?
    I wanted to use filters and filter them by System Type but it System type doesn't appear on the list.
    So I could filter heating pipework on one drawing soils on another, domestic on another, gas on another etc
    I could use a filter on system name > contains > (Some abbreviation)
    This is leaving it to other users to name everything properly then and I was hoping to hard code my filters into our template.
    Domsib
    Revit MEP - 1 Day at a time...
    Use System Classification.
      System classification will only pick up Cold Water for instance. I have 2 types of cold water, boosted and mains. How do I split these if the classification is filtered containing the word Cold.
      Domsib
        In that case, you can use "System abbreviation", which is a property of the system, not of the pipe type. Select one of the pipes that are assigned to the Cold Water - Boosted system classification, then click on Piping System > Edit Type > System abbreviation. Then, use the abbreviation as your filtering criteria, under "System abbreviation" in the Filter dialog box.
          Alfredo,
          Domsib
            Uncheck "Piping Systems" the system has diferent parameters and is not visible in the view anyway.
            System Abreviation is what I use too. Its a good idea to name everything that is a similar type of system in the same way. For example tw-c tw-w tw-r for tap water instead of cw, ww, rw or something. Then you can use "Begins with tw" to show/filter them all.
            I also tend to make 'not' filters. For example "System Abreviation does not begin with tw" with visibility off, to get rid of everything except what you want to show. Means you only need one filter per view instead of one for every system.
            Oh, and leave the System Name alone, it gets changed every time you split or join systems anyway and the automatic name is "system abbreviation"+Number. So just set up as many pipe system types as you need and let revit do the naming.
            Filtering Mech Equipment, or showing just duct heaters and not all the other duct accessories, also needs another way of filtering. I use Type Comments and list all the disciplines it should be visible in. For example Duct heater Type Comments = Air Heat, FCU = Air Heat Cool Drain Then you can filter with Contains.
            I suggest clearly writing up a list of standard disciplines and putting them in all your families.
            (Unless someone has a better method?)
              Joseph. Brilliant thank you.
              Domsib
                If you use tw-cw for your cold water system abv, how do you tag your pipes?
                  Just with either that code or the system type name. Its also shown in a legend with all the system types and colours, linetypes etc.
                  Its not as neat as a single letter, but if you really want the acad style regularly repeated single letter along the pipe, its actually faster to do that with a line based annotation.
                  • Riser Diagrams
                    any good threads or thoughts on creating view templates for plumbing riser diagrams?
                    I am trying to set up view templates to place in my project...
                    July 12, 2017, 11:12 PM
                  • LW
                    can a pipe system parameter be included in the pipe schedule field?
                    May 17, 2018, 05:09 PM
                  • Filtering
                    See attached. I need to filter by system type (ie storm, sewer, etc.) and also grab the associated hangers. The wall I ran into is operator limitation,...
                    November 16, 2015, 04:06 PM
                  • System Types and names
                    Hi all,
                    Slight issue on revit 2014 (projects version), I have a Domestic Cold Water Service feeding a Break Tank from the incoming into the...
                    October 20, 2014, 10:33 AM
                  • Piping Systems
                    Currently we have 64 different Piping Systems. When it comes to filters, I have managed to group some of them by system classification. However, some...
                    August 13, 2014, 05:51 PM
