Printing to PDF
    Printing to PDF
    When I print to pdf one of my sheet views it comes out different to what is shown, for instances all my Arch' is greyish but when PDFs the walls are showing firewalls in colour and lots of detail?
    anyone know what the problem is?
    Cheers
    Check your print settings - any of the settings I highlighted could affect it. You might also have one view on your sheet and a separate view that you are working in - double check which view you are in.
    chad
      The views that im trying to print are documentation views I set up for the sheets, tried messing about with vector and raster.. not sure what it is?
        A snip of what your screen shows of the sheet view vs print view can be helpful in this case...and another of the PDF view...
          Documnet.JPGView before printing to PDF
          Print.JPGPrint after PDF
            Is your original view in wireframe perhaps? Wonder if that is why you are not seeing the color in the linked file. You will probably need to override the linked file's materials/object styles to be none since you are printing your drawings in color. Printing to black only should work fine.
            And really, I don't like it when I get PDF's that the piping is in color. When I try to print them to my B&W copier the pipes are too light.
              It is set to hidden line in the model display
                In properties, check your view template against the pdf's printing correctly. A change in the view temp can change printing, I think.
                  Originally posted by ruellesmith
                  Have you tried checking your print settings? I used to have this problem too and after searching on the web for possible causes, I found out that my print settings were not right. The few adjustments I made fixed my printing problem.
                  Not sure what to change there is only a few settings
                    Are you stacking views on your sheet? If the underlay view has the color fill you will see it, especially if you are in wireframe.
                    chad
