Text Issue
    Text Issue
    I have an intermittent issue with text and cannot figure out a cause for it. As the picture below shows, the text is left justified but the drag icon is in the lower right corner. The text will not give me a tracking line on the left or the top, only on the right or bottom. I have other text of the same style that tracks left and top with the same properties.
    This has happened to me before. But it usually happens when I have rotated the text 180 deg. Did you rotate the text?
    Yes or no, just try to rotate it 180 deg and that may work.
    Is the issue repetitive or is it just in one instance?
      Use the rotate command to do what aykhan9 said.
      -Alex Cunningham
        You can also use the rotate icon in the lower left corner of your image. It also happens when you mirror text.
        Dan
          Thank you for the replies. It is because the text has been rotated. Not sure how this happened because all of our text is horizontal.
