Custom solar thermal piping system
    Hello,
    I am trying to design a piping layout for an unconventional experimental research project. I have a house model created by our architect and I have used conceptual masses to represent the equipment the piping will be running to in the basement so I can't use any automatic routing features that I've seen discussed in tutorials. (It would be laborious and time consuming to try and create components to represent each piece of equipment so I hope that is not necessary.)
    I have used flexible piping to model a below-ground hydronic system with a serpentine layout (see images below).
    However, I would like to run piping up from this underground system into the basement and route it to various equipment. I also need to run a plethora of pipe runs between individual pieces of equipment in the basement.
    Ojectives:
    1. Use this as a design tool to figure out where to place piping and how to connect everything.
    2. To show my consultants and contractors the whole picture in terms of placement of equipment and piping.
    Problems:
    1. I can't figure out how to run pipe vertically, I can only place it horizontally and offset from the current work plane (I can't figure out how to set a vertical work plane as I can't click on any lines or planes when I click 'set' from the 'work planes' tab).
    2. All of the help files and courses talk about plumbing as though its always done in the plan view and its connecting to standard equipment.
    If anyone can explain to me how to get started on this, it would be very much appreciated. I am at my wits end!
    Originally posted by briana.paige View Post
    Problems:
    Looks like a neat project! Running pipe vertically is fairly simple and there are a few ways to do it. The easiest way is:
    Start your pipe command (notice the offset parameter in your properties bar). Draw a segment of pipe but don't exit the pipe command. Then change your offset to the next height you want. In the video, I'm going from -1'-0" to 5'-0". Continue to draw your pipe segment and Revit will draw the vertical pipe connecting the two segments.
    I made a short video showing this process. Hope it helps: http://screencast.com/t/s6kCG0PQ
    You can also cut a section and draw your pipe that way, but it's just as easy to do in plan view.
      Thanks so much for your reply. I'm going to follow your directions and I'll report back on how it goes!
        That worked perfectly, I really appreciate your help. Cheers!
        • Creating Pipework Routes
          I am still trying to get used to working with Revit, finding it frustrating, seem to be going 2 steps forward 3 steps back.
          I appreciate all the...
          February 1, 2015, 11:04 AM
        • Wye combo w/ 8th bend
          I have inserted the wye combo w/ 8th bend into my project and have used it some. Now I have one look up off a sloped pipe and would like to add a vertical...
          December 16, 2014, 08:49 PM
        • Pipe disappearing issue
          Dear all,
          I am confused,....
          Any one can help me and give me a several reasons for disappearing the pipes from the floor plan.
          I am...
          September 13, 2016, 09:41 PM
        • Sanitary Pipe Fittings
          I am trying to do my first Sanitary system, i have managed to do my main stack and come off to WC, i am trying to bring a 40mm pipe from the WHB to the...
          October 22, 2015, 11:48 AM
        • Connections Pipework
          new to revit MEP on first project trying to connect pipework to boiler, I have added a potterton boiler, has connections
          I am trying to connect...
          May 22, 2014, 11:21 AM
