Space Separation Line View Properties
    Hello,
    I'm working on a zoning diagram using spaces and was wondering if it was possible to edit space separation lines such that they are not halftone and are not hidden behind the walls. Alternatively, is it possible to edit the border around spaces in plan view to make it thicker/more visible? Right now it is difficult to differentiate between the zones in an open floor plan. Thank you for your help!
    Holly
    In the "Manage" tab, look under "Additional Settings" to find line types. You can change to anything you want right there.
      Line styles not types and you can just manipulate the space separation lines.
      In Object Styles you can control HVAC Zones (2012). You can only see the boundary and Color fill in hidden line mode.
      have you considered a Color Fill Legend for HVAC zones?
      As far as the red outline and light green color fill for spaces, I think those are hard coded or similar to phases where the color is defined in the materials library.
      If anyone knows I also would like to know.
        I meant styles...
          Thanks for the replies. I edited the space separation lines, but couldn't find a way to turn off the half-tone appearance. However, I just started defining zones, which fixed my issue because the zone boundary appears darker and its appearance can be adjusted. I am also using a color scheme for the spaces.
