Two Way Elbow Connector
    I am not able get a two way elbow connector in RMEP 2009.
    I had attached a snapshot of needed fitting.
    Is it possible to get a such connection with RMEP?
    Yogesh
  • Conduit Connection Auto insert Connector
    Is there a way when connecting a conduit to a panel that a connector can be inserted automatically? See attached. I have a connector family but I have...
    November 19, 2014, 06:55 PM
  • Pipe size connectors!!
    This is my first post here.
    I am making my own version of an excisting family. When i load the family's in a project i can change the connector...
    October 15, 2018, 07:07 PM
  • Snap only on connector
    hello
    i'd like to know of it's possible that the dimensions only snap to connectors
    i have a flange adaptator designed and i'd like that dimensions...
    October 16, 2019, 08:09 AM
  • Flex pipes
    ive got a piece of equipment with 4 connectors 2 hydronic supply and 2 return.
    I cant get the flex pipes to connect to right connector it...
    April 1, 2016, 03:09 PM
  • Revit OpEd: Revit MEP Family Wisdom - Connector Orientation
    This is snipped from the Revit Family Editor Tutorial for Revit 2008 as mentioned in yesterday's post. You can download the PDF copy HERE.
    Connector
    March 19, 2014, 05:15 PM
