Duct Visibility Elbow up vs Elbow dn
    When my elbow turns down, the X is dashed (supply) as well as three sides of the fitting. Great. When my elbow turns up the X is also dashed but I want it to be solid. I don't see anything in the MEP settings for Duct Rise/ Drop besides the symbol you want to use. Is there another setting for the linetype you want to show for a Rise/ Drop?
    thanks
    I have also encountered this issue. Within the MEP settings I see no way of changing the drop/rise settings to show diffrent details for above or below. I have been using text annotations to work around this.
      It has to do with whether or not your duct penetrates the top plane of your view range.
      If your duct goes through the top of your view range - it should show up solid.
        Thanks, I dind't even think of view range, lately I am just as happy if I get a system connected properly!
          That view range will get you every time... I'm have tons of issues with connecting to piping underground. I want to be able to see the plan and run piping into the correct room. But when I move the view range down I can't see the floor. So I have to create some ref planes all over the place, really wish there was an easier way to do that.
            Have you tried playing around with the View Depth. To show the piping underground we have changed the view depth to be unlimited on the ground level and changed the <Beyond> Linetype to be Dashed inorder to show anything that is underslab in the model to be shown as dashed. I am not sure if this what you are looking for.
            Also, attached is a diagram that helped me understand view ranges a little better perhaps it will be usefull to someone.
              Great Diagram. I wish the view range was graphically set, like going into a section or elevation and drag the extents of the Top, Bottom etc. I have tried moving the depth down enough to pick up the under slab piping but all the walls ( either dashed or not) seemed too much.
              I read in a thread "Over There" about changinging the RVT Link Display Settings but can't remember which ones. Does anyone remember that thread?
                forum 1.JPGWhat is the purpose of the visibility range between the bottom clip plane and the view depth plane?
                I thought that whatever's viewable in your plan view would be whatever is between the top and bottom clip plane w/ elements being cut that are in the cut plane, view depth plane just being extraneous property.
                • Vertical duct issue
                  This as only been an issue in Revit2019. Ducts drawn vertically are shown as being hatched as if they are penetrating the level above or below in plan...
                  October 3, 2018, 07:45 PM
                • Invisible duct risers
                  Hi everyone,
                  I'm having an issue in Revit 2012 where all ducts drawn that run perpendicular to the plane I am viewing are invisible, i.e. duct...
                  August 18, 2011, 07:37 PM
                • Corridor ductwork question
                  I know Revit pretty well, but am a total newbie when it comes to MEP. I'm running coordination drawings for a project and the MEP is being done in CAD...
                  September 10, 2015, 02:27 AM
                • Seeking RECTANGULAR DUCT ELBOW - Radius...But VERTICAL?
                  Gang,
                  I am a Revit Architecture 2013 user trying to drop in some basic ductwork.
                  Of course my suite does not have any duct families....
                  October 10, 2013, 01:19 AM
                • change duct/pipe size
                  hello
                  i have a small duct to modify, the diameter has to increase because flow increases.
                  i asked to some of my colleagues who told that i...
                  April 28, 2017, 01:57 PM
