Connector doesn't follow nested family
    I've made an in-line pump where I've nested the suction guide and flow-trex/multi-purpose/angle valve into the main pump family, which I've placed my connectors onto. The connectors maintain the correct location across different pump sizes, but after a certain point (bigness), the connector on the valve no longer follows the changing geometry. I.e. the connector is positioned correctly at sizes =< 150 mm, but positioned incorrectly at sizes >= 200 mm.
    I tried placing the connector on both the biggest version and smallest version as this sometimes seems to work if I've had connector issues, but to no avail. Nothing changes in the family except for the dimensions of the geometry. I've also tried changing the dimensions in my pump family as that also seems to sometimes "refresh" what's happening in the family, but also no luck on that front.
    I poached the suction guide and valve from the OOTB Revit library, and the only modifications I've made is to reduce the number of parameters and delete the connectors out of them. I've modified the pump family itself from the manufacturer so the parameters and geometry are not quite to my liking, but never had any issues with the family before.
    I've never had any problems like this before so I'm super confused......:crazy::crazy::crazy:
  • Connectors and nested faces
    In a book by Shawn Zirbes, "Revit 2010-Family Standards and Best Practices" it said that placing connectors on a nested face is a bad idea and...
    June 20, 2011, 02:29 PM
  • Pipe size connectors!!
    This is my first post here.
    I am making my own version of an excisting family. When i load the family's in a project i can change the connector...
    October 15, 2018, 07:07 PM
  • Nested Duct Connector
    Hi All
    I have a family with parameters that determine how many connection there should be, have modeled an extrusion for the connection (face...
    February 27, 2017, 12:45 PM
  • Flex pipes
    ive got a piece of equipment with 4 connectors 2 hydronic supply and 2 return.
    I cant get the flex pipes to connect to right connector it...
    April 1, 2016, 03:09 PM
  • Snap only on connector
    hello
    i'd like to know of it's possible that the dimensions only snap to connectors
    i have a flange adaptator designed and i'd like that dimensions...
    October 16, 2019, 08:09 AM
