Pipe Elbow Tick Sizing
    I am completely blanking on a solution to my tick size altering at different elbow angles. How can I program the tick size to stay consistent with each angle?
    The tick size parameter is currently: Fitting Outside Diameter *0.4
    Fitting Outside Diameter: Nominal Diameter *1.1
    Thank you in advance
    -RenChan
    I usually constrain the ends of the lines to the geometry of the fitting, so that the line length is the actual width of the thing.
    If thats not required I think it is actually better/neater to not show them at all, or use fixed sized round points or short lines that are the same in every family.
      I have the tick size constrained and my company prefers to be the tick size the same size regardless of the pipe size. Right now it works like that EXCEPT it does not obey my constraints when the angle is not 90°. In fact the tick size grows the larger the angle. I can't figure out how to further constrain the tick size when it should just be reading off the nominal diameter.
        Personally, my global solution to this is to remove the ticks altogether. I don't use them anymore for any reason. I don't even use radius elbows on single line - all mitered. Ticks are a drafting standard and while I personally think ticks do look good, It's too much trouble to try and use them in a BIM environment like Revit, so I changed my standard to better fit the way programs work in today's BIM world.
        -TZ
        Tannar Z. Frampton ™
        Frampton & Associates, Inc.
          My company and I prefer to see the ticks and we use radius elbows because we also do shop drawings and spools. I was just having trouble getting the tick size to obey the constraints when doing different angles. I did find the solution on another site. The parameter just needed to be: "Fitting Outside Diameter * 0.4 * tan(Angle / 2)" for the tick size.
          Thank you all for responding, I declare case closed.
            No problem. This will most likely continue to be a nuisance unless you are using only these few fittings and no more. Since I use a lot of different fittings I had to decide on constantly manipulating things based on nothing more than an old drafting standard/preference, or make it easy. I think it's cleaner and easier to read in the longrun without fitting ticks so I won't be going back regardless. Lines, Pipe up/down, and that's it for me.
            -TZ
            • Sizing pipe fittings
              Hi guys I have a problem:
              I would like to size pipes for domestic water with an equation...
              With Dynamo it's possible to do it but...
              October 14, 2015, 10:55 PM
            • Filter Pipes by size
              I work in an Architecture-only firm, so I'm pretty much a n00b where MEP is concerned.
              I'm trying to set up a filter to show only the larger pipes....
              January 11, 2016, 02:53 PM
            • Annotation nominal diametter piping
              Hi all,
              Is there anyone know how to make annotation nominal diameter?
              Plz see attachment for example:
              I need to...
              October 17, 2014, 03:51 AM
            • Pipe fitting bend radius issue
              Can someone please shed some light on an issue for me.
              Working with Revit MEP, I am creating new pipe fittings and have come stuck on one...
              January 7, 2013, 02:24 AM
            • Changing Pipe Sizes
              When I have to change the size of several pipes (and fittings) what I have to do is select all the pipes and changes their size (no problem here) but...
              December 22, 2014, 07:12 AM
