Label Visibility Hanger Tag
    I am creating a hanger tag and would like to control a label based on whether or not the parameter has a value. I would like to have two labels in one place and have one turn off if the parameter is null and the other one stay on. Is this even possible?
    The bad news is revit currently can't handle having a family drive visibility within a tag. The way to do this is have 2 types within the tag family and the users will need to select the correct one.
      Thanks for the reply. Guess two separate tags it will be.
        You might be able to use a new formula in the family to determine the status of the parameters and use this in your tag instead. Not if its text but maybe otherwise.
        Greg McDowell Jr
        about.me/GMcDowellJr
