I've searched profusely, but most posts center around actually creating a parameter from the Offset constraint which has all of the integrity of a built-in parameter. I'm not that adventurous.
What I have on my hands is a huge project with hundreds of receptacles for power and data, at many different heights. It looks like the way the architect has defined their height AFF is by first floor-hosting them, then setting a vertical offset manually for every device. Now, I already have an electrical fixture schedule showing all of the outlets, room names and numbers, etc. All I want is to add that manually-entered offset number to the schedule.
I don't care about being able to modify it once it's made. I just want to be able to populate a new schedule column with the number the architect entered into that Offset box for each outlet. That's all.
I've been messing around with shared parameters and GUIDs for built-in parameters and such, but haven't had any luck. If anyone has any ideas, I'd love to hear them.
Thanks!
Thanks!
