rectangular duct multiport conversion
    Can anyone help me find a revit family - rectangular duct fitting - 30x18 to 22x18 & 8 x18 these last 2 are side by side
    I made this family for doing any kind of divided duct. Its basically a flat plate with one duct on one side and two on the other. The two ducts are always aligned to the two oposite corners of the plate, so they can be side by side or above eachother depending on the sizes. I find it very useful for making all kinds of split junctions with one or two bends after the split etc. because you can just use normal revit elbows to make any size or angle you like.
    Disclaimer: You can use and alter this as much as you like but if you dont know how it works or you break it dont ask me to fix it .
      Thanks my friend! I got pulled off onto another job at the moment. I did end up making my own .. it was quichk and dirty ... I will look at yours and will also upload mine in the near future .. when I get back to this project. Are you going to AU this year?
        thank you. add friendly
        Revit, Revitmaster,Học Revit,Revit Architecture,Revit Structure,Revit Mep
          I can put this to use... thanks!!
          Tannar Z. Frampton ™
          Frampton & Associates, Inc.
          • Accessory - inserted into duct.
            Good morning all,
            I need to build a fire damper family. Trick is it doesn't break the ductwork. It's slid into place IN the duct. If I'm...
            July 6, 2015, 07:01 AM
          • Corridor ductwork question
            I know Revit pretty well, but am a total newbie when it comes to MEP. I'm running coordination drawings for a project and the MEP is being done in CAD...
            September 10, 2015, 01:27 AM
          • Duct connections
            I have a 700 x 700 duct and have another duct 700 x 300 above, which i want to drop down which i would like to connect it into
            i cant seem to do...
            December 4, 2014, 10:44 AM
          • Tapers
            Anyone know where I can find this type of taper?
            The standard ones loaded into my project from Revit don't come off with a straight edge,...
            April 3, 2014, 02:36 PM
          • Duct Segments
            I work for an HVAC manufacture / installation company which has recently acquired Revit MEP. As square ducting is manufactured in segments of approximately...
            November 21, 2013, 12:27 PM
