Duct Connector Configurations
    For those that create there own mechanical equipment families with duct connectors, attached is a diagram showing the duct connector configurations from Kyle Bernhardt, Author of (http://inside-the-system.typepad.com/my_weblog/)
    Actually, I created that diagram. I'm not sure who marked it up, but I agree with the corrections.
    Jason Seck
    Design Technologist
    Black & Veatch - Water Division
      Well sorry for the misrecognition it is a great diagram I just wanted to make sure and preserve it. Also I want thank you for sharing this because it has been very helpful in explaining connections to other people with it.
        On this topic, if a family has multiple hvac connectors, like a in-line exhaust fan that has a intake side and a exhaust side, which connector would you link the shared parameter for airflow (CFM value)?
        http://www.captiveaire.com/
        Commercial Kitchen Ventilation Systems
          For an inline exhaust fan we used the exhaust system for both sides but (refering to the diagram of this post) the intake side was setup similar to the return side of the AHU and the exhaust side was similar to the supply.
            What I am asking is which connector, inlet or discharge, do you associate the shared paramter Airflow to? I see some families that associate both connectors to the parameter, but this seems like its incorrect and the system would calculate the CFM for the unit twice.
              Sorry for the delayed responces. Associating the parameter to both connectors would not double the cfm, it just assoicates the parameter to the connectors. This allows you to change the parameter value in the family types dialog and it would apply to the connectors as well.
